[GRASS5] new Linux Binaries
Markus Neteler neteler at geog.uni-hannover.de
Thu May 31 03:27:12 EDT 2001
On Thu, May 31, 2001 at 09:52:29AM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > On Wed, May 30, 2001 at 03:19:28PM +0200, mlennert at ulb.ac.be wrote:
> > > Markus,
> > > Can I recreate the Linux binaries with the May 20 snapshot, or
> > > should I use a new snapshot with the latest changes ?
> > Personally I would prefer the latest code (due to new Xdriver
> > improvements). However, this would be 5.0.0pre1b. Or shall I re-tag
> > and we produce 5.0.0pre2 ?
> If we are going to produce another release then it should be named
> 5.0.0pre2. I see no reason for using multiple versions of pre1.
O.k. (good luck that pre1 is not anounced yet :-)
Perhaps we should wait until the V_stuff is fixed? Glynn, Huidae, do
you have a timeline for this?
Regards
 Markus
