[GRASS5] Re: Terminal Errors
andy agena andya at inebraska.com
Fri May 18 08:12:41 EDT 2001
Glynn and Jeshua:
> Yep; MacOS X has a broken curses installation. Are there any mailing
> lists, web sites etc specifically for MacOS X issues? If there are,
> they would probably be of more help than this list. This problem is
> unlikely to be specific to GRASS; any program which tries to use
> curses should suffer from the same problems.
The darwin list at apple is probably the best for this question:
http://www.lists.apple.com/mailman/listinfo/darwin-development
But there's also the developer list at omni:
http://www.omnigroup.com/mailman/listinfo/macosx-dev
Andy
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
