[GRASS5] Terminal Errors (was: nothing to do with r.reclass)
Jeshua Lacock jeshua at SierraMaps.com
Thu May 17 19:22:53 EDT 2001
On Thursday, May 17, 2001, at 01:27 PM, andy agena wrote:
> this sounds a lot like the problem i had, except mine was 'error
> opening terminal: vt100'.  strobe solution was  to the directory where
> your spearfish directory is (i.e. if its found in /opt/spearfish, cd
> /opt) and enter the following:
> 	grass5 spearfish/PERMANENT
>> I was trying out the GUI a bit and if I choose Create New Location in
>> the GRASS opening dialog, the program crashes (maybe). At least, it
>> disappears.
>> Here is the message when the program seems to disappear:
>> Error opening terminal: xterm.
Yes, I used Andy's "fix" to launch Grass.  That is fine, thanks.
However, if I try and use g.region (command line or GUI) to create a new
region, I get the error "Error opening terminal: xterm." inside XFree86,
and inside of a "Aqua" Terminal window, I get "Error opening terminal:
vt100."
Now, typing in "grass5 spearfish/PERMANENT" will not help me create a
new region, so I am stuck and if g.region doesn't work, what else?  It
used to work with Mac OS X public beta.
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
