[GRASS5] [bug #269] (grass) Grass5 and NFS
Glynn Clements glynn.clements at virgin.net
Thu May 17 09:02:50 EDT 2001
Request Tracker wrote:
> at the command d.mon start=x0 it asnwers that it can't complite the
> locking procedure.
> Indeed the dir for locking is exported by nfs and it doesn't have the
> permision to write on it.
> So maybe there is a env-variable to change in order to make grass lock
> at a dir with write permision.
An environment variable is probably a bad idea; in order for lock
files to work, all processes have to use the same path. With an
environment variable, this may not happen.
It may be worth making it a compile-time option, though.
BTW: what is this directory used for?
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
