[GRASS5] r.reclass
Bob Covill bcovill at tekmap.ns.ca
Thu May 17 07:50:20 EDT 2001
"Roger S. Miller" wrote:
> Folks,
> Was anyone taking on the bug in r.reclass that produces an error when a
> user enters floating-point category numbers?  I have run into that problem
> myself, so I wouldn't mind fixing it.  Just scanning the code I can see
> some readily fixable problems.
> I don't want to go any further if someone else is already working on it.
> Others certainly know more than I do about the inner workings of
> reclassification, so before I go on I have a second question.  Is it even
> possible to reclassify a CELL raster map with FCELL or DCELL category
> numbers, thus getting a reclass map that is a different type from the
> original map?
> Roger Miller
> Lee Wilson and Associates
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Roger,
The routines used in r.recode use the routines defined in the GIS lib in
the file fpreclass.c (libes/gis/fpreclass.c). These routines allow for
reclassification to and from all three raster types (CELL, FCELL, &
DCELL).
Rather than trying to fix r.reclass, it might be easier to make r.recode
accept the same classification rules as r.reclass.
Hope this helps.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
