[GRASS5] Re: [GRASS_DE] r.mapcalc round()
Markus Neteler
neteler at geog.uni-hannover.de
Tue May 15 16:37:07 EDT 2001
On Tue, May 15, 2001 at 07:51:51PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > Does this go away if you compile r.univar with "-ffloat-store"?
> > Well, r.univar is only a script using r.stats and awk. However, after
> > recompiling r.stats with above flag (adding
> > EXTRA_CFLAGS=-ffloat-store
> > to the r.stats' Gmakefile) I can't see any difference.
> That wouldn't help; it's the awk script which is doing the relevant
> calculations. Looking at the awk script, I don't think that compiling
> awk with -ffloat-store would help.
> The problem is basically that none of the axioms of real arithmetic
> quite hold true for floating-point arithmetic.
> In this particular case, the variance is:
> (SUM[x(i)^2] - SUM[x(i)]^2/N)/N
> If all of the x(i)'s are identical, then the two sides of the
> subtraction should be equal. However, given the error introduced by
> each floating point operation, they will differ slightly; if the RHS
> is slightly larger, then result will be negative, causing the sqrt()
> to fail.
> Whilst there probably is an algorithmic solution (a decent textbook on
> numerical methods should list many approaches for working around the
> problems inherent in floating-point subtraction), I'm not sure whether
> that would be justified, or if it would be better to just include an
> explicit check for a negative variance (indicating a variance so low
> that it's been swamped by rounding error).
Perhaps I am wrong, but doesn't the problems in r.univar result from
the input data? If r.mapcalc produces wrong numbers, the r.univar shouldn't
be better. Here, the r.univar replicates the values generated from
r.mapcalc. So the problem may be in r.mapcalc.
The range results of r.mapcalc are quite strange with FP numbers.
Even if I compile r.mapcalc with -ffloat-store the result is odd:
r.mapcalc test=1.1
CREATING SUPPORT FILES FOR test
range: 1.1000000238 1.1000000238
Regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
