[GRASS5] Re: [GRASS_DE] r.mapcalc round()
Markus Neteler
neteler at geog.uni-hannover.de
Tue May 15 09:52:14 EDT 2001
Hi Dieter,
(cc to grass5)
On Tue, May 15, 2001 at 03:01:36PM +0200, Dieter Lehmann wrote:
> Hi,
> r.mapcalc test='float(x)/10'
> results in something like 0.0200000002.
what are the contents of "x"?
> I need to round. The function round() in mapcalc gives only the next integer.
> My problem might be solved in mapcalc or in r.stats (I need to export the
> values through r.stats -1 test).
However, something is odd with r.mapcalc in my opinion:
r.mapcalc x1=1.4
EXECUTING x1 = ... 100%
CREATING SUPPORT FILES FOR x1
range: 1.3999999762 1.3999999762
r.stats x1
r.stats: 100%
1.4-1.4
but:
r.stats -1 x1
1.3999999762
1.3999999762
1.3999999762
1.3999999762
1.3999999762
-> not what I expect.
r.univar x1
Minimum: 1.3999999762
Maximum: 1.3999999762
Range: 0
Arithmetic Mean: 1.4
Variance: -2.49502e-12
awk: cmd. line:17: (FILENAME=- FNR=18894) warning: sqrt called with negative argument -2.49502e-12
Standarddeviation: nan
-> huh!
r.mapcalc x2=1.6
EXECUTING x2 = ... 100%
CREATING SUPPORT FILES FOR x2
range: 1.6000000238 1.6000000238
-> does not look very impressive.
r.mapcalc x0=1
EXECUTING x0 = ... 100%
CREATING SUPPORT FILES FOR x0
range: 1 1
-> o.k.
Starting to round:
r.mapcalc x1round="round(x1)"
EXECUTING x1round = ... 100%
CREATING SUPPORT FILES FOR x1round
range: 1 1
-> rounding is o.k.
r.mapcalc x2round="round(x2)"
EXECUTING x2round = ... 100%
CREATING SUPPORT FILES FOR x2round
range: 2 2
-> rounding is o.k.
r.mapcalc x3="1.6 + 1."
EXECUTING x3 = ... 100%
CREATING SUPPORT FILES FOR x3
range: 2.5999999046 2.5999999046
-> huh?
Perhaps someone could explain this behaviour. Or is it a precision bug?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
