[GRASS5] Re: Vector format proposal
Radim Blazek
Radim.Blazek at dhv.cz
Tue May 15 02:48:27 EDT 2001
Eric G. Miller wrote:
> Well, here's my two cents on data models.
> I fully agree with David regarding graphic vs. topological
> representations of "entities". I've seen plenty of shapefiles with
> screwed up geometry to know this is a real problem. But, I'll grant the
> topological "coverage" concept is a bit more complex to manage vs. the
> graphic representation.
> In regards to attribute tables: I would think a one to one mapping from
> each map entity to an attribute table via a unique integer key is the
> best solution. So, for each AREA, LINE, SITE, LABEL, NODE, etc there is
> a table. It might be, we want to maintain some separation between
> internal numberings and what the user uses for a key. Otherwise we
> can't change a numbering after an edit/rebuild cycle because the linkage
> with the attributes will be broken. A simple two integer table is all
> that is needed, the user is only presented with setting the "user_id"
> whereas the other is maintained by the system. Example:
> AREA_ID | USER_ID
> 1 | 1
> 2 | 1
> 3 | 2
> 4 | 1
> So, when v.digit asks for a "category number" it sets the "USER_ID" with
> whatever the user wants, but the "AREA_ID" is incremented as the next
> largest value (for that table). A rebuild might renumber the "AREA_ID"
> to make them sequential, but the "USER_ID" is never touched. Thus,
> linkage to external tables always works. I think I'm getting redundant
> here ;)
USER_ID is category in grass and AREA_ID is sequential number assigned
during build process. Link to table may not be broken. Lib is written in this
way.
Radim
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
