[GRASS5] Locale Not Supported Warning
Bernhard Reiter bernhard at intevation.de
Sun May 13 18:02:04 EDT 2001
On Sat, May 12, 2001 at 02:01:56PM -0700, Jeshua Lacock wrote:
> I just wanted to report the following warning, even though everything
> seems to work fine.
> When I fire up a new monitor via the tcltk GUI, I get the following
> warning:
>    Error: Warning: locale not supported by C library, locale unchanged.
> What does it mean?  Is it safe to ignore?
It has to do with the internationalisation possibilities of your system.
Obviously a program request another locale as standard (which is "C" for
U.S. English). If everythings works you can savely ignore it.
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010514/e668791e/attachment.bin
