[GRASS5] memory leakage in r.sunmask
Markus Neteler neteler at geog.uni-hannover.de
Fri May 11 11:51:25 EDT 2001
Hi all,
unfortunately there seems to be a memory leakage in r.sunmask (which
calculates cast shadows in a DEM). I am trying to find the bug, but
cannot find it.
If you run the module on a DEM with 1000x1000 pixels or more, you
may see that more and more memory is used... Here it regularly
crashes part of the system as no overflow protection is present.
I would be glad to receive hints how to trace down the bug.
src/raster/r.sunmask/main.c
It must occur within the loops... Here it consumed in a
1700x2000 DEM more than 100MB already when processing the
100th line. Later half the system would die.
Thanks in advance,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
