[GRASS5] NVIZ update
Markus Neteler
neteler at geog.uni-hannover.de
Tue May 8 03:43:46 EDT 2001
Hi Bob,
thanks for these updates. Here some test results:
On Mon, May 07, 2001 at 04:07:57PM -0300, Bob Covill wrote:
> Hello,
> I have applied some change to NVIZ and the ogsf library.
> NVIZ is now started with the script "nviz" not "nviz2.2".
> All commands are handled by the G_parser and NVIZ should exit gracefully
> when incorrect parameters or flags are used.
that's working well.
> The interactive version (no options) is working with parameters and
> flags supplied from prompt. Simply type "nviz".
working well.
A problem occurs when trying to load a non-existing raster map:
nviz elev=notthere
WARNING: unable to find [notthere] in [(null)]
WARNING: unable to open raster map [notthere in (null)]
Not able to open cellfile for [notthere]
Adding panels from /usr/local/grass5/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
child killed: segmentation violation
For vector it is o.k.:
Can't find vector file notthere.
For sites also o.k.:
Can't find sites file notthere.
Could you look into this again?
> I have updated the loading status for rasters and vectors where the
> percent complete is shown.
Working, too.
> I have added a catch for the memory check when loading raster data. This
> allows a graceful exit if there is not enough system memory to load the
> data.
Perfect!
> To incorporate the above changes update the ogsf library and NVIZ2.2.
> If there are any problems or questions let me know.
Beside above minor problem I cannot see further difficulties. Thanks!
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
