[GRASS5] GRASS packaging issues
Jan-Oliver Wagner jan at intevation.de
Mon May 7 07:36:45 EDT 2001
On Mon, May 07, 2001 at 12:31:01PM +0100, Markus Neteler wrote:
> On Mon, May 07, 2001 at 12:14:29PM +0200, Jan-Oliver Wagner wrote:
> > - the installation routine copies several CVS directories.
> Do you think of "grass5install.sh"? It anything else?
> Within GRASS' Gmakefiles there are various "tar" calls, unfortunately
> the "exclude" parameter of tar is not portable.
the copying of CVS directories happens when executing 'make install'.
IMO, if tar can't do the job cross-plattform it should be replaced
by alternative methods to install. AFAIK it is unusual to use
tar for installing anyway.
Jan
Jan-Oliver Wagner               http://intevation.de/~jan/
Intevation GmbH	              	     http://intevation.de/
FreeGIS	                               http://freegis.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
