[GRASS5] PAGER changed to GRASS_PAGER
Markus Neteler neteler at geog.uni-hannover.de
Mon May 7 05:15:20 EDT 2001
On Sat, May 05, 2001 at 12:34:49AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > I would suspect that most of the actual programs can be changed,
> > > > although more consideration needs to be given to library functions.
> > > > It seems conceivable that spawning "less" in the wrong place (e.g.
> > > > from within an interactive program) might cause problems.
> > > Hmmm. Then we probably should list this as a TODO item and leave
> > > changing "more" to "GRASS_PAGER" until after 5.0. Markus, any comments?
> > Of course we should experiment too much now... However, I dislike the
> > "less" behaviour in i.group and others, if you "list" the existing
> > groups. reason: "less" doesn't exit immediately but waits for the user
> > pressing "q" to quit. That's very inconvenient. If I switch to "more",
> > the available groups are listed and "more" is left.
> Does setting GRASS_PAGER to "less -F" help? From the less manpage:
>        -F or --quit-if-one-screen
>               Causes less to automatically  exit  if  the  entire
>               file can be displayed on the first screen.
> Or does this screw other cases?
Glynn,
no, this doesn't work:
if you run "i.group" and enter "list" into the first screen, you
would get:
hit RETURN to continue -->
instead of (using "more"):
Available groups
no group files available
The less -F erases the screen when quiting while more keeps it.
> In any case, I wasn't suggesting hard-coding "more" in cases where
> "less" was "not ideal". I was more concerned about the possibility of
> it trashing terminal settings. I don't see this as an issue within
> individual programs; If it occurs, the program can be modified to
> reset the terminal to the desired state afterwards.
> I was more concerned about ensuring that library functions don't have
> undesirable side effects.
Yes, agreed. Thanks for the other fixes. This problem seems not to be
trivial...
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
