[GRASS5] [bug #244] (grass) d.rast.num: some numbers are displayed
in wrong (unreadable) color
Glynn Clements
glynn.clements at virgin.net
Thu May 3 02:04:17 EDT 2001
Request Tracker wrote:
> d.rast.num: some numbers are displayed in wrong (unreadable) color
Can anyone confirm that this is a real bug? Or does it come from not
using d.rast first? (AFAICT, d.rast.num draws the text in either black
or white, depending upon whether the cell is light or dark
respectively).
In any case, there should probably be an option to set the text
colour, so that d.rast doesn't have to be used first.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
