[GRASS5] XDRIVER colour changes
    Markus Neteler
    neteler at geog.uni-hannover.de
    Wed May  2 08:54:07 EDT 2001
On Wed, May 02, 2001 at 09:24:18AM +0100, Glynn Clements wrote:
> I've just committed a bunch of non-trivial changes to XDRIVER's colour
> handling. If they cause anyone problems, the previous version can be
> retrieved using the "color_changes_20010502" tag.
> The changes should result in better output in "fixed" colour mode on
> all visual types. I've tested it on XFree86, on 8/15/16/24-bit
> TrueColor and DirectColor visuals, and on 4/8-bit StaticGray,
> GrayScale, StaticColor and PseudoColor visuals (needless to say, 4-bit
> visuals don't produce particularly nice output).
> If anyone has a system with other visual types, feedback would be
> appreciated.
> Also, I had to force the use of a private Colormap for DirectColor
> visuals, mainly due to being unable to figure out how to do any colour
> handling other beyond filling an empty Colormap with writable colour
> cells.
> If anyone knows of some worthwhile[1] documentation on the details of
> X Colormap handling (and DirectColor visuals in particular), I'd
> appreciate the information.
> [1] as opposed to the X manpages and the Xlib documention in
> xc/doc/hardcopy/X11.
Glynn,
the solaris compile is done. At least working remote on solaris
fails:
d.mon x0
ncolors: 65536
(sometimes I get:
Can't bind to socket for monitor <x0>. Already in use?
Socket is already in use or not accepting connections.
Use d.mon to select a monitor
Problem selecting x0. Will try once more
Then the window opens, but I still see my Linux KDE background.
Wiping with another window or iconizing/resizing makes it black.
d.rast nations
Monitor remains as it is, wiping with another window or iconizing/resizing
makes the map visible. It seems to be a backing store problem.
Note: I didn't change anything on Linux, it must have to do with working
on the SUN remotely.
Sorry for no better news, please tell me how to help debugging...
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
