[GRASS5] [bug #260] (grass) v.trim: removes islands from vector map
Request Tracker grass-bugs at intevation.de
Wed May 2 07:58:02 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=260
Subject: v.trim: removes islands from vector map
If a polygon has island, v.trim removes such islands from the
 vector file... urgh! I've obtained such a behaviour with a map obtained
 with r.poly, v.support, I don't know if there is a relation (my map was a
 reclassified DEM).
 (reported by: Andrea Aime <aaime at comune.modena.it>)
 -> needs a total rewrite!!
-------------------------------------------- Managed by Request Tracker
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
