[GRASS5] [bug #251] (grass) r.stats: some inconsistent results
comparing to r.average
Request Tracker
grass-bugs at intevation.de
Wed May 2 07:52:33 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=251
Subject: r.stats: some inconsistent results comparing to r.average
*First, I compute the per-class averages:
r.average base=medv cover=test out=borra.me
*Second, I check the result for, i.e., class 23:
d.what.rast map=medv,borra.me
2676500(E) 4409500(N)
medv in user1 (23)S_SUPRAMEDITERRANEAN_ZONE
borra.me in user1, quant (111)
borra.me in user1, actual (110.794075)
*Third, I compute the statistics for each class, but the results are not
the same as given by d.what.rast. For example, for class 23:
r.stats -c in=medv,borra.me
r.stats: 100%
23 110.299171-110.744906 6082
*While d.what.rast was giving 110.794075. Is this a bug?
Dr. Agustin Lobo, alobo at ija.csic.es
-------------------------------------------- Managed by Request Tracker
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
