[GRASS5] [bug #253] (grass) r.watershed: needs to be *partly* updated
to GRASS 5 FP/NULL
Request Tracker
grass-bugs at intevation.de
Wed May 2 07:53:45 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=253
Subject: r.watershed: needs to be *partly* updated to GRASS 5 FP/NULL
Helena Mitasova wrote:
Drainage map should be INT, there is no reason for it to be FP
because the program uses D8 algorithm, there are only 8 directions
of flow. only L and S factor could be output as FP (here they are
multiplied by 100) but I am not sure whether it is worth the effort
because they are not very good anyway.
-------------------------------------------- Managed by Request Tracker
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
