[GRASS5] Driver Update
Glynn Clements
glynn.clements at virgin.net
Wed May 2 04:00:17 EDT 2001
Justin Hickey wrote:
> > I've commited an update to
> > src/display/devices/lib/command.c which checks the return value from
> > the write() call, in case that's failing for some reason.
> Now that I could compile again, I tried d.mon and it seems that there is
> no change in the output. That is, the write() call doesn't seem to be
> failing. Here's the output.
OK, I'm an idiot; I can't believe it took me this long to notice this.
"c" changed from a "char" to an "int" when the "switch" was made into
a separate function (process_command()).
This doesn't affect anyone whose platform is little-endian (e.g.
Intel), but on a big-endian platform it's sending a zero instead of
the COMMAND_ESC (127) which terminates the sequence. The client waits
forever for a COMMAND_ESC which never arrives.
Are you really the only person testing this on a big-endian platform?
I suppose you must be.
I reckon that the attached patch (or the latest CVS version[1]) will
fix it.
[1] I've just checked a lot of other XDRIVER changes into CVS, so you
may wish to try just this first.
Glynn Clements <glynn.clements at virgin.net>
--- command.c~ Mon Apr 30 11:11:59 2001
+++ command.c Wed May 2 08:46:00 2001
@@ -82,19 +82,20 @@
ITEM *item;
LIST *list;
PAD *pad;
+ unsigned char ch;
switch(c)
case BEGIN:
- c = 0;
+ ch = 0;
for (index = -10; index < BEGIN_SYNC_COUNT; index++)
- SEND(&c, 1);
- c = COMMAND_ESC;
- SEND(&c, 1);
+ SEND(&ch, 1);
+ ch = COMMAND_ESC;
+ SEND(&ch, 1);
break;
case RESPOND:
Respond();
- SEND(&c, 1);
+ SEND(&ch, 1);
break;
case GET_NUM_COLORS:
Number_of_colors(&index);
