[GRASS5] Re: V_ stuff
Huidae Cho hdcho at geni.cemtlo.com
Tue May 1 20:37:21 EDT 2001
From: Glynn Clements <glynn.clements at virgin.net>
> Markus Neteler wrote:
> > below is a thread on asian characters support in GRASS which
> > will become feasible with a small change proposed by Artemis.
> > Huidae Cho has already implemented related improvements into
> > v.digit etc. It seems that the fix would help various people
> > so we should include it.
> > Read on below for details. Huidae, in case of no objections by
> > the others, could you update this in CVS?
> > > > There's something you should know about Vask.
> > > > V_support.c should have:
> > > > 	in line 51 the substring:
> > > > 		&& (*ANS_PTR < '\177') *
> > > > 	should be deleted.
> > > > V_call.c:
> > > > 	in line 254:
> > > > 		& 0177
> > > > 	should be deleted.
> > > > 	in line 410:
> > > > 		&& (newchar < '\176')
> > > > 	should be deleted.
> > > Yes, actually it helps one type asian characters. So I updated v.digit in
> > > this way and added DASIAN_CHARS into head.in some months ago.
> > > If others are ok, what about adding --with-asian-chars to configure.in.
> > > Without this flag, i have to add DASIAN_CHARS to head.* by hand after
> > > configure.
> I don't see any point in making this optional; if GRASS copes with
> 8-bit characters, then it may as well be unconditional.
> Presumably this applies to all non-ASCII character sets, not just
> Asian ones (many people would assume that ASIAN_CHARS refers to
> multi-byte encodings such as ISO-2022).
> BTW, I noticed this in V_call.c:
> 	c = getch() & 0177;
> This is the wrong thing to do, for several reasons:
> 1. As EOF is usually -1, the "&" is going to convert it to \177, so
> the "if(c == EOF)" test on the following line will fail.
> 2. If someone enters a top-bit-set character, and GRASS can't cope
> with them, the correct solution is to reject it, not to silently
> convert it to some completely unrelated character.
> 3. GRASS *ought* to be able to cope with it. If there are bugs related
> to char signed-ness, let's fix them rather than introducing a
> workaround which ensures that they'll never be found.
> Also, "newchar" should probably be an "int"; this avoids the issue of
> top-bit-set characters being negative. "int" variables are also likely
> to be more efficient than "char" (or, for that matter, "short").
Hi all,
Glynn, you're right. So I added '#ifdef ASIAN_CHARS' to input an exceptional
characters such as asian chars. It does not affect any behaviour without
DASIAN_CHARS in head.$(ARCH).
For this, I didn't change var types of "newchar" and etc.
> Huidae; do you want to deal with this, or shall I? For now, I'll leave
> it alone unless told otherwise.
I don't know the side effects of this ASIAN_CHARS fix exactly. It's
just test code because I didn't see where >128 char is used for now.
So it would be nice to leave it untouched until this fix turns out ok.
Yours,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
