[GRASS5] Release branch broken
Huidae Cho hdcho at geni.cemtlo.com
Tue May 1 07:16:02 EDT 2001
> Hello all
> The current code in the release branch will not compile. The following
> error message was reported.
> gmake5.0 - UNUSED variable NULL or not set
> src/CMD/generic/GISGEN.sh[13]: gmake5.0:  not found
> *** Error code 1 (bu21)
> I think Huidae made a change concerning this UNUSED variable. Huidae,
> can you take a look at this?
Hi all,
Ooops! I forgot to announce this change. UNUSED env var was added to compile
unused/ stuff. Sorry for this inconvenience.
This can be resolved by recreating gmake5 script.
However, I've removed UNUSED check. So it'll work now.
Yours,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
