[GRASS5] [bug #823] (grass) rast problems dealing with null maps on DEC Alpha (Linux)
Glynn Clements
glynn.clements at virgin.net
Fri Nov 2 02:12:36 EST 2001
Request Tracker wrote:
> Subject: rast problems dealing with null maps on DEC Alpha (Linux)
> Anything to do with floating point raster maps with null map on a DEC Alpha
> causes a
> floating point exception... FIX taken from source of Grass 4.2.1 with FP +
> NULL patches is to not use NaN to mark nulls in floating point maps but
> rather to use FLT_MAX...
That isn't a fix, but a workaround.
Do you have any idea what causes the FP exception? Or is it any
attempt to perform FP operations on NaN values?
Glynn Clements <glynn.clements at virgin.net>
