[GRASS5] [bug #820] (grass) Idea: links for g.remove, g.list,, g.rename maybe others
    Glynn Clements
    glynn.clements at virgin.net
    Fri Nov  9 07:35:13 EST 2001
Markus Neteler wrote:
> On Thu, Nov 01, 2001 at 08:44:48AM +0100, Request Tracker wrote:
> > Related to this:
> > g.remove behaves almost as I would like to... if no data
> > type specifier is given, it defaults to rast. IMHO that is quite
> > dangerous. If I want to remove the vector cover my_dear_map and manages to
> > writes g.remove my_dear_map (because that is more similiar to a typical
> > unix shell command), it removes quite happily the raster file
> > my_dear_map....
> I agree - at least for g.remove [g.mremove] there should be no default
> data type to avoid above potential problem.
> Any objections to change g.remove?
No objection; but how do you intend to implement it?
AFAICT, the behaviour in question is built into G_parser(). An
argument which neither begins with a dash nor contains an equals sign
is treated as the value of the first (non-flag) option.
You could add a dummy option to the beginning of the list, but then
that would show up in the "help" and "--interface-description" output,
which isn't ideal. OTOH, it isn't as bad as inadvertently deleting the
wrong map.
Is it worth extending G_parser() for this case?
Glynn Clements <glynn.clements at virgin.net>
