[GRASS5] odbc interface with postgres - db.tables error
sixote alin sixote at yahoo.com
Sun Nov 11 08:33:58 EST 2001
Hi
I can run other db.* modules with odbc-postgresql
driver, except for
db.tables that gets "dbmi: Protocol error" message and
terminates.
unlike other db.* modules, f.e. db.columns, which also
call macro
DB_RECV_RETURN_CODE and it returns DB_OK to them,
db_list_tables
calls the following macro chain (line 14,
c_list_tabs.c):
DB_START_PROCEDURE_CALL(DB_PROC_LIST_TABLES);
that either should return error or pass through; so it
does the second,
but later the call to db__recv_int would invoke
db_protocol_error().
As far as I traced the calls from grass to rpc libs,
those were:
db.tables --> db_list_tables -> DB_RECV_RETURN_CODE
--> db__recv_return_code --> DB_RECV_INT -->
db__recv_int --> xdr_begin_recv -->
--> xdrstdio_create
Used sources from CVS Nov.9, Linux RH 7.1/postgresql
-7.1.3
--alex
__________________________________________________
Do You Yahoo!?
Find a job, post your resume.
http://careers.yahoo.com
