[GRASS5] standards
Roger S. Miller
rgrmill at rt66.com
Sun Nov 11 13:03:28 EST 2001
Folks,
I'm writing a couple routines to support the USGS MODFLOW ground water
model under GRASS 5.0. So far this is just a command to create a raster
file from the contents of MODFLOW Well, Drain or River input files and
another to create a raster file from binary head or drawdown files.
Creating raster files from binary cell-by-cell flow files is a fairly
simple extension.
If these routines are generally useful I would be glad to have them
incorporated in GRASS. I won't release them otherwise, because I don't
want to do 3rd party support.
I have three questions.
First, is has anyone already done this?
Second is with the C-standard that can be most dependably used in
GRASS. What I've written so far uses ANSI-C and ISO standard
functions. I avoided functions that aren't covered in one of those two
standards. Which standards can be most dependably be used in GRASS?
Third is with testing material. MODFLOW is a FORTRAN program, and its
binary output files use an internal structure that is generally unique
to the compiler with which the program is compiled. I use g77, so I
have no problem testing my work with g77 files. Probably most of the
people in my industry use Lahey fortran, but I only have one example of
a MODFLOW binary file from a version compiled with Lahey. Is there
anyone out there who can send me a MODFLOW binary output file from a
version compiled with Lahey?
Roger Miller
