[GRASS5] new raster fixes
Markus Neteler
neteler at itc.it
Mon Nov 12 05:22:30 EST 2001
On Mon, Nov 12, 2001 at 12:22:10AM +0100, Markus Neteler wrote:
> Hi,
> I have fixed a few things:
> - r.thin writes NULL instead of 0 (src/raster/r.thin/cmd/io.c)
> - r.digit writes NULL instead of zero
> (fix applied in src/raster/r.in.poly/raster.c)
> For the latter I am not sure how we treat 0 categories.
> But the NULL fix was needed to avoid other problems.
I just realized that r.mfiler also outputs 0 instead
of NULL.
All r.thin, r.digit (r.in.poly), r.mfiler seem to use unusual
write routines (or not?). At least I am not very sure how
zero shall be treated. In general 0 should be supported.
Maybe my above changes switched that off for r.thin and r.digit?
r.mfiler is untouched so far.
I am clueless here,
Markus
