[GRASS5] r.in.gdal: gdalbridge bug
Glynn Clements glynn.clements at virgin.net
Tue Nov 20 01:04:29 EST 2001
Markus Neteler wrote:
> > I have found that r.in.gdal ignores the LD_LIBRARY_PATH
> > settings. The reason is that in
> > src/raster/r.in.gdal/gdalbridge.c
> > #ifdef __unix__
> > is used which obviously doesn't exists.
It's defined by the preprocessor:
	$ echo > foo.c
	$ gcc -E -dM foo.c | fgrep unix
	#define __unix 1
	#define __unix__ 1
	#define unix 1
> A follow up:
> Perhaps the LD_LIBRARY_PATH is caught elsewhere. However,
> r.in.gdal is currently ignoring the LD_LIBRARY_PATH
> settings from the current GRASS session which makes it
> difficult to run different GDAL implementations.
AFAIK, it isn't ignoring it, but it's only used if the GDAL library
can't be found in $GISBASE/lib or $GDAL_HOME.
For each of the names:
	libgdal.1.1.so
	gdal.1.0.so
	gdal.so.1.0
	libgdal.so.1
gdalbridge.c calls dlopen() on:
	$GISBASE/lib/<name>
	$GDAL_HOME/<name>
	<name>
The last of these will look for the library using the same mechanism
as used by ld-linux.so; i.e. first search all directories in
$LD_LIBRARY_PATH, then look for an entry in /etc/ld.so.cache.
Note: using the configure switch "--with-gdal" should bypass
gdalbridge.c altogether; libgdal will just be linked in as with any
other shared library.
Glynn Clements <glynn.clements at virgin.net>
