[GRASS5] [bug #837] (grass) g.remove
guest user via RT
grass-bugs at intevation.de
Thu Nov 29 15:22:35 EST 2001
Hi again on the g.remove/mapset bug.
I can confirm that it exists:
RASS:~ > g.list rast
raster files available in mapset user1:
archheights fields.areas file2 streams.thin v1 vegcover.clump
archrast fields.areas1 mysoils test v1.clump
raster files available in mapset PERMANENT:
aspect landuse rushmore soils.Tfactor trn.sites
density owner slope spot.image uparea
elevation.dem quads soil.br.depth streams vegcover
elevation.dted railroads soils strm.dist
erode.index residential soils.Kfactor texture
fields roads soils.ph tractids
geology rstrct.areas soils.range transport.misc
GRASS:~ > g.remove vegcover.clump
[vegcover.clump at user1] is a base map. Remove reclassed map first:
vegcover.1000 at user1
Looks like a bug to me,
Markus
-------------------------------------------- Managed by Request Tracker
