[GRASS5] probs with i.points
Heiko Kehlenbrink
heiko.kehlenbrink at vermes.fh-oldenburg.de
Thu Oct 4 03:16:56 EDT 2001
Hi Markus!
Markus Neteler wrote:
> Well, since you are working in an xy-location, how can your images
> overlap?
I'm working in 1 xy-location but i have created 2 mapsets , let us call them import and
mosaik.
In import i've got 9 aerial images, in "mosaik" the left 1 wich becomes the origin of the
target system in
the transformation.
> Generally: It is much more recommended to use i.ortho.photo to
> rectify aerial images. Only then the results will be really accurate.
Yeah, i'm thinking of that too, but i don't have a dem , only a bunch of about 8 points
with gk-koordinates and heights from
wich i can identify 4 in the image.
Should i interpolate a "dem" out of them or creat a plain dummie-dem with r.mapcalc using a
mean height for example?
Best Regards
Heiko
