[GRASS5] Darwin Pre2: PNGDriver
Markus Neteler
neteler at itc.it
Mon Oct 15 10:01:06 EDT 2001
On Mon, Oct 15, 2001 at 02:16:39PM +0100, Glynn Clements wrote:
> jeshua wrote:
> > >> Will I have to re-build everything and start out with a "make
> > >> distclean", or will I be able to just run configure and then build the
> > >> PNGDriver?
> > > It should suffice to run configure then build PNGdriver.
> > Thank you! I checked-out all of the config files and ran configure
> > again and it was apparently successful:
> > checking whether to use PNG... yes
> > checking for location of PNG includes...
> > checking for png.h... yes
> > checking for location of PNG library...
> > checking for png_read_image in -lpng... yes
> > checking whether to use GD... yes
> > checking for location of GD includes...
> > checking for gd.h... yes
> > checking for location of GD library...
> > checking for gdImagePng in -lgd... no
> > checking for gdImagePng in -lgd... yes
> > checking for gdImagePng in -lgd... (cached) yes
> > checking for gdImageGif in -lgd... no
> > Built then when I go to build the PNGDriver I run into trouble with
> > undefined symbols:
> > gcc -o /usr/src/grass/dist.powerpc-apple-darwin1.4/driver/PNG
> > OBJ.powerpc-apple-darwin1.4/Can_do.o OBJ.powerpc-apple-darwin1.4/Color.o
> > OBJ.powerpc-apple-darwin1.4/Draw_line.o OBJ.powerpc-apple-
> > darwin1.4/Get_w_box.o OBJ.powerpc-apple-darwin1.4/Get_w_line.o
> > OBJ.powerpc-apple-darwin1.4/Get_w_pnt.o OBJ.powerpc-apple-
> > darwin1.4/Graph_Clse.o OBJ.powerpc-apple-darwin1.4/Graph_Set.o
> > OBJ.powerpc-apple-darwin1.4/Panel.o OBJ.powerpc-apple-
> > darwin1.4/Polygn_abs.o OBJ.powerpc-apple-darwin1.4/Reset_clr.o
> > /usr/src/grass/src/display/devices/lib/LIB.powerpc-apple-
> > darwin1.4/driverlib.a /usr/src/grass/src/libes/LIB.powerpc-apple-
> > darwin1.4/libgis.a -lz -L/usr/local/pgsql -L/usr/local/lib
> Er, there's no "-lgd" in there.
> I suspect that gmake5 is using the old make.rules file; try:
> cd /usr/src/grass
> rm -rf src/display/devices/PNGdriver/OBJ.powerpc-apple-darwin1.4
> gmake5 src/display/devices/PNGdriver
Another way to do this is
make pre-compile
Markus
