[GRASS5] Bug: vector maps shifted (d.area / d.vect)
Markus Neteler
neteler at itc.it
Sat Oct 20 02:41:11 EDT 2001
just found an inconsistency: d.area draws maps
shifted to north-west.
I have generated a polygon with r.digit, the vectorized
with r.poly. Comparing d.vect and d.rast the overlay
looks perfect, while d.area produces a shifted result.
Also v.area is not consistent (I guess d.area and v.area
have a similar code history).
Is anyone willing to fix these two problems before releasing
5.0.0?
Thanks in advance,
Markus
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20011020/d64ccc16/darea_dvect_bug.gif
