[GRASSLIST:2599] Re: [GRASS5] RE: RE: d.area: areas filled with various colors
Glynn Clements
glynn.clements at virgin.net
Tue Oct 23 13:56:11 EDT 2001
Eric G. Miller wrote:
> > > > With respect to the new vector format expected in Grass5.1(?), I was
> > > > wondering if this automatic color filling is planned. When dealing with
> > > > very large vector maps we need some way to do this. At present I just
> > > > convert my map to raster and create categories. This does not create too
> > > > many problems but certainly working directly with the vectors will be
> > > > better.
> > > This is more a limitation imposed by the GRASS display architechture than
> > > anything with the vector data representation.
> > This is a limitation imposed by vector layers not having colour
> > tables.
> So your saying if I used R_color() to set a color, and then
> subsequently performed a vector drawing command that the display
> drivers would do the right thing? I was under the impression that
> vector and text graphics were limited to the named colors.
You would first need to call R_reset_color() to associate an RGB value
with a colour index.
Basically:
R_reset_color() sends RESET_COLOR, receipt of which calls
Reset_color() -> _fixed_Reset_color() -> assign_fixed_color()
which sets an entry in the {pos,neg}_color_lookup arrays.
R_reset_colors() is similar.
R_color sends COLOR, receipt of which calls
Color() -> _get_color_index() -> get_fixed_color()
which gets an entry from the {pos,neg}_color_lookup arrays, and makes
this colour "current" for subsequent single-colour drawing operations
(i.e. not rasters) via the (driver-specific) color() function.
Raster operations also use the {pos,neg}_color_lookup arrays, via
_get_color_index_array().
The standard colours are initialised at driver startup, by the driver
calling assign_standard_color() directly, which sets an entry in the
standard_colors array.
R_standard_color() sends STANDARD_COLOR, receipt of which calls
Standard_color() -> get_standard_color()
which gets an entry from the standard_colors array, and makes this
colour "current" for subsequent single-colour drawing operations (i.e.
Also, the driver startup initialises the fixed colour indices 1-13
(corresponding to the constants in colors.h) to the standard colours
so that, unless subsequently changed, R_color() has the same effect as
R_standard_color() for the indices 1-13.
> programming manual:
> 16.9 Colors
> int D_reset_colors (struct Colors *colors)
> Turns color information provided in the colors structure into color
> requests to the graphics driver. These colors are for raster graphics,
> not lines or text. See 12.10.3 Raster Color Table (p. 116) for GIS
> Library routines which use this structure.
This function doesn't seem to exist. At least, not in
src/libes/display/*.c or src/include/display.h.
D_set_colors() does exist with that prototype; that calls
R_reset_colors(), which would affect the RGB colour selected by calls
to R_color(). However, this function probably isn't appropriate for
anything other than raster graphics.
> int D_translate_color (char *name)
> Takes a color name in ascii and returns the color number for that color.
> Returns 0 if color is not known. The color number returned is for lines
> and text, not raster graphics.
This translates the string "red" to the constant RED etc. The return
values can be passed to R_standard_color(), or to R_color() provided
that the colours haven't been changed from their initial setting (but
this shouldn't be relied upon).
Glynn Clements <glynn.clements at virgin.net>
