[GRASS5] pre2 nviz & darwin
Glynn Clements
glynn.clements at virgin.net
Thu Oct 25 11:29:02 EDT 2001
andy agena wrote:
> i have grass5pre2 running on darwin1.4 (osx 10.1) and received the
> following error when trying to launch nviz. most of my *.dylib are in
> /usr/lib; i only have a few tcltk *.dylib's in /usr/local/lib.
> GRASS 5.0.0pre2 > nviz
> dyld: /usr/local/grass5/etc/nviz2.2/NVWISH2.2 can't open library:
> /usr/local/lib/libdl.dylib (No such file or directory, errno = 2)
Odd. Is libdl.dylib present on your system, in /usr/lib,
/usr/local/lib or elsewhere?
FWIW, try removing $(DLLIB) from src.contrib/GMSL/NVIZ2.2/src/Gmakefile;
if Tcl needs libdl, configure will add -ldl to TCLTKLIBS.
Glynn Clements <glynn.clements at virgin.net>
