[GRASS5] pre2 nviz & darwin -- part ii
andy agena andya at mac.com
Thu Oct 25 14:41:11 EDT 2001
Hi Helena:
both ways returned the "wait_ok" error.
andy
On Thursday, October 25, 2001, at 11:29 AM, Helena wrote:
> andy
> try nviz -q
> it will open nviz and then go to panels->surfaces and load new surface
> to see
> whether it will work.
> you can also try to type nviz elevation.dem, but it should have worked
> the
> way you did it -
> it loks like a bug.
> Helena
> agena wrote:
>> hi again:
>> jeshua zapped me libdl.a and libdl.dylib, so i have them installed now.
>> however, if i try nviz from tcltkgrass, the command passed is "nviz
>> el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
>> if i try from the cli, i get :  "ERROR: window name "wait_ok" already
>> exists in parent..."
>> any ideas?
>> thanks,
>> andy
>> On Thursday, October 25, 2001, at 10:29 AM, Glynn Clements wrote:
>>> andy agena wrote:
>>>> i have grass5pre2 running on darwin1.4 (osx 10.1) and received the
>>>> following error when trying to launch nviz.  most of my *.dylib are
>>>> in
>>>> /usr/lib; i only have a few tcltk *.dylib's in /usr/local/lib.
>>>> GRASS 5.0.0pre2 > nviz
>>>> dyld: /usr/local/grass5/etc/nviz2.2/NVWISH2.2 can't open library:
>>>> /usr/local/lib/libdl.dylib  (No such file or directory, errno = 2)
>>> Odd. Is libdl.dylib present on your system, in /usr/lib,
>>> /usr/local/lib or elsewhere?
>>> FWIW, try removing $(DLLIB) from
>>> src.contrib/GMSL/NVIZ2.2/src/Gmakefile;
>>> if Tcl needs libdl, configure will add -ldl to TCLTKLIBS.
>>> Glynn Clements <glynn.clements at virgin.net>
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
