[GRASS5] pre2 nviz & darwin -- part ii
Glynn Clements
glynn.clements at virgin.net
Fri Oct 26 13:09:00 EDT 2001
andy agena wrote:
> >> however, if i try nviz from tcltkgrass, the command passed is "nviz
> >> el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
> > Odd; that works fine here, both from the command line and via
> > tcltkgrass.
> > What does "nviz help" say?
> GRASS 5.0.0pre2 > nviz help
[snip]
That implies that the error message is bogus, i.e. a problem with
G_parser(), but I can't see anything obvious.
Glynn Clements <glynn.clements at virgin.net>
