[GRASS5] d.what.vect, v.area, d.area needs update manual
Eric G. Miller
egm2 at jps.net
Wed Oct 31 13:03:06 EST 2001
On Wed, 31 Oct 2001 18:50:46 +0100, Markus Neteler <neteler at itc.it> wrote:
[snip]
> > We also have v.area which outputs everything that d.what.vect does plus
> > perimeter, area centroid and island info (and the "mouse clicking" is
> > different - that is one standard that needs to be set for 5.1)
> > Point at cross hairs: 4918382.22 (N) 602540.00 (E)
> > Getting value 0 with opflag 0
> > Islands flag is 0
> > Area index number: 79
> > Perimeter: 8613.35 meters 28258.68 feet 5.352 miles
> > Area: 2557050.00 sq meters 255.71 hectares
> > 631.845 acres 0.9873 sq miles
> > Area centroid: 4918410.00 (N) 602490.00 (E)
> > cat#= 9, label= <CBE>
> > and then we also have d.area for which the manual says: Obtains
> > area/perimeter information on vector polygons, which it is not doing? but
> > it has the capability to display areas as filled areas that the previous
> > two do not have.
> I agree, that's a sort of confusing.
The man page and description for d.area have been fixed. Note, v.area does
filled polygons using the '-f' flag upon selection -- but it doesn't handle
islands or clipping correctly (similar polygon clipping problem that d.area
has).
Eric G. Miller <egm2 at jps.net>
