[GRASS5] GRASS 5.0.0pre2 released
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 13 23:29:51 EDT 2001
Markus Neteler wrote:
> o For r.in.gdal we need "libgdal" which has to be included into the GRASS
> binary package. Finally store "libgdal.1.1.so" in $GISBASE/lib/
> It is highly recommended to get the latest GDAL CVS version:
> export CVSROOT=:pserver:anonymous at cvs.remotesensing.org:/cvsroot
> cvs login
> Password: anonymous
> cvs checkout gdal
> configure --without-python ; make;
> make install
> cp /usr/local/lib/libgdal.1.1.so /usr/local/grass5/lib
> # this copies the libgdal into GRASS binaries
> If above fails, get the precompiled GDAL library:
> - Get Linux version here:
> ftp://gdal.velocet.ca/pub/outgoing/libgdal-linux-grass.tar.gz
> (Note: check "ldd libgdal.1.1.so" dependency, get if required:
> ftp://gdal.velocet.ca/pub/outgoing/libstdc++-libc6.2-2.so.3)
> - Other precompiled libgdal versions:
> http://gdal.velocet.ca/projects/grass/index.html
> - Get GDAL sources at:
> http://www.remotesensing.org/gdal/
Folks,
I will try to prepare a GDAL 1.1.5 final release tomorrow, and I will build
libgdal for selected platforms (Linux, Solaris and IRIX) in "GRASS" mode.
I am happy to support anyone needing to build GDAL on other platforms for
release with GRASS.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
