[GRASS5] most recent snapshot
rgrmill at rt66.com rgrmill at rt66.com
Mon Apr 8 18:58:11 EDT 2002
Glynn wrote:
> Can you provide error messages? Building NVIZ is complicated by
> depending upon OpenGL and Tcl/Tk, both of which have variations
> depending upon platform and version.
This mail client only allows me to send such things as attachments.  I
ran gmake5 in the NVIZ2.2 directory and attached the last part of the
file.
> Can you tell whether the snapshot is based upon the (now defunct)
> release branch, or the head? If there are any "CVS/Tag" files, it's
> the release branch.
There is a tag file. It contains
Treleasebranch_11_april_2001_5_0_0
> I made some changes in that area. Basically, I changed the invocation
> of lex and yacc so that they use the default filenames (lex.yy.c,
> y.tab.[ch]). These are the files which the "maintainer-clean" target
> now removes. If the snapshot was installed over an existing
directory,
> or if "make maintainer-clean" wasn't run prior to creating the
> snapshot, that might cause problems.
As it happens, I did install it over my pre2 release.  I didn't expect
to, but I had a soft link from "grass" to "grass5.0.0pre2".  The top
level directory in the tar ball was named "grass" so when I unpacked the
tar ball it installed on top of my pre2 installation.  I lost some work
because of that, but it was my own fault.
It would have been nice if the tar ball had a non-generic name for it's
top-level directory like the normal tar ball releases do.
Anyway, I did a "make distclean" on the pre2 directory before I
installed the snapshot over it, not "make maintainer-clean".
Roger Miller
/home/roger/grass5.Mar_22_2002/src/libes/ogsf
  make -f OBJ.i686-pc-linux-gnu/make.rules
make[2]: Entering directory `/home/roger/grass5.Mar_22_2002/src/libes/ogsf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/roger/grass5.Mar_22_2002/src/libes/ogsf'
touch nviz_init.c
gcc -I/home/roger/grass/src/include -g -O2   -I/usr/X11R6/include   -I/home/roger/grass/src/libes/ogsf  -D_NO_PROTO -D__STDC__   -I/usr/local/pgsql/include  -c nviz_init.c -o OBJ.i686-pc-linux-gnu/nviz_init.o
make[1]: *** No rule to make target `sed', needed by `nvwish'.  Stop.
make[1]: Leaving directory `/home/roger/grass5.Mar_22_2002/src.contrib/GMSL/NVIZ2.2/src'
make: *** [nvwish] Error 2
