[GRASS5] most recent snapshot
Markus Neteler
neteler at itc.it
Wed Apr 10 04:20:53 EDT 2002
On Tue, Apr 09, 2002 at 01:26:55AM +0100, Glynn Clements wrote:
> Roger Miller wrote:
> > I dowloaded and compiled the most recent snapshot (March 22) and thought I'd
> > report. First, the changes to the monitor setup are a great improvement over
> > pre2. I can now once more run GRASS monitors over a slow link.
> Having just checked the GRASS website, the issue has become more
> clear.
> The download page (http://grass.itc.it/download.html) lists four
> options:
> Source Code for GRASS 5.0.0pre3: latest
> official (pre-)release of the GRASS source
> code based on the release branch below.
> CVS release branch snapshot: a subset of
> the experimental code frozen to only allow
> bug fixes. Considered fairly stable code
> CVS experimental tree (HEAD) snapshot:
> The overall GRASS code base. Modules
> which get stable are added to the release
> branch, but this tree also contains less stable
> modules such as the G3D voxel tools.
> Direct access to GRASS-CVS server
> The second option ("CVS release branch snapshot") is effectively
> defunct, as the release branch was terminated on March 22. The third
> option ("CVS experimental tree (HEAD) snapshot") has a snapshot dated
> April 5.
> Someone should update this page to reflect the fact that the "release
> branch" snapshots are no longer being generated. Actually, that option
> should probably just be removed for now, as the snapshot to which it
> refers has the problems which Roger reported.
Yes. Every developer with write access can do that:
http://grass.itc.it/grasscvs.html
GRASS site web pages management (developers only)
Developers have access to maintain the GRASS web pages:
Set the CVSROOT variable (with your CVS ID)
cvs -z3 co web
The web site is updated by a cronjob in the early
Italian morning.
especially in case I am traveling around... I'll be offline till next week.
Best
Markus
