[GRASS5] line types
Radim Blazek
blazek at itc.it
Thu Apr 11 04:45:00 EDT 2002
On Wednesday 10 April 2002 07:08 pm, rgrmill at rt66.com wrote:
> What do you regard as a clean data set? If you mean one for which the
> build reports no errors then we have a logical problem.
Clean data fulfil "6.7 Vector Topology Rules" in Programmer's Manual.
> v.transform has always reported errors doing builds.
Vector without errors had errors after v.transform?
> Some errors may not even be reported.
Which errors are not reported.
> It is more of a problem to me that GRASS offers no good tool
> for finding and fixing the problems.
That is also problem for me, and that is challenge for future. It is not
simple task, David can talk about that.
> I use the edge type when I can, but it isn't always possible. For
> instance, US Census Bureau Tiger County Line data are broken down into
> line objects and area object.
So they use a model with edge/line distinction?
> I don't believe I have an option of
> importing roads (typed as line objects) as area edges. In fact, most of
> the GRASS import packages do not give one the choice of line type. That
> means that for dxf data and for many important public data sources
> (USGS, NRCS and US Census, for instance) I have to accept whatever line
> type the import package decides to set.
There are v.line2area and v.area2line - scripts based on v.out/in.ascii, I
want to write v.type working on binary files. It is true that import modules
are usually missing that option and I know that it is useful (v.in.dgn has
type= option for example).
> The the only way you can get data that is consistent with the GRASS
> line/area edge distinction is to digitize it in GRASS. And you can only
> reasonably manipulate that distinction if you're working with small data
> sets. That is very limiting. It isn't even very well supported in
> GRASS.
You can get consitent data to GRASS, what you only need, is to sort
lines and edges during the import. Is it problem to run?:
v.in.dxf lines=rivers type=line
v.in.dxf lines=lakes type=edge
(Of course if type= was available, now with v.line2area following the later)
> The line/area edge distinctions causes a lot more problems then it has
> has advantages, and in every case where there appears to be a use for
> the difference there also appears to be a workable alternative.
What is an alternative for example with forests, fields and roads in my last
mail?
Radim
