[GRASS5] GRASS terminal mode (curses) and backspace key
Markus Neteler
neteler at itc.it
Tue Apr 16 10:11:09 EDT 2002
On Tue, Apr 16, 2002 at 02:26:19PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > a small problem which would be great to have fixed is that the
> > backspace key does not erase. Currently it is implemented as
> > left arrow key. It will be more conventient to also have it
> > inserting white space when using the backspace.
> > Is anyone there who knows to change
> > src/libes/vask/V_call.c
> Done.
Cool! Glynn, you are close to real-time programming!
Thanks a lot,
Markus
