[GRASS5] Zoom
Helena Mitasova hmitaso at unity.ncsu.edu
Tue Apr 16 12:42:42 EDT 2002
Radim
I was one of the advocates for the change in d.zoom. However at this point
I would suggest just to change the buttons for unzoom and quit to make it
consistent with other GRASS d.* programs. Your suggestions are very good but
as
I understand it there is only few days left before the release and that is
not enough for testing.
It would be good to hear from others,
Helena
Blazek wrote:
> Hi,
> it was already mentioned in grass list few times, that d.zoom could be
> modified, because I also think so, here is my proposal how to do that:
> Prerequisities (for discussion):
> 1. Most improtant zoom operations:
>    - zoom in by window
>    - zoom out by point
>    - pan by point
> 2. Right button used for "Quit/Go to upper menu". Right button is already
>    used for quit by many functions in v.digit.
> 3. d.zoom and Zoom in v.digit must be identical.
> 4. Menu should not have more than 2 levels, more levels are confusing.
> 5. No need to ask always user if he realy wants to do what he already
>    selected.
> Proposed behaviour for d.zoom:
> Main menu:
> L:Zoom menu
> M:Pan
> R:Quit
> Zoom menu - Mode 1:
> L: 1. corner + switch to mode 2.
> M: Unzoom
> R: Main menu
> Zoom menu - Mode 2:
> L: 1. corner (reset)
> M: 2. corner
> R: Main menu
> This (or something better) should be done before 5.0.0 release, I think.
> Modified module is here:
> http://mpa.itc.it/radim/g50/d.zoom2.tar.gz
> and precompiled version for Linux/i386:
> Radim
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
