[GRASS5] bug: d.vect.area and HTMLMAP
Markus Neteler neteler at itc.it
Tue Apr 16 12:22:01 EDT 2002
sorry for a new bug report: It seems that d.vect.area does not work properly
with the HTMLMAP driver (d.area was fine).
Please update:
 cvs up src/scripts/contrib/grassmirrorsmap
then
 cd src/scripts/contrib/grassmirrorsmap
 mkgrassmap.sh
The resulting 'grass_sites.gif' is fine, but the 'grass_sites.htmlmap' does
not contain the expected polygon definitions. Using the old d.area the
procedure went fine.
I need that to generate the mirrors world map:
http://grass.itc.it/index.html
Eric, could you please check for a difference between the old and the
new implementation which may concern the HTMLMAP driver?
Thanks,
 Markus
