[GRASS5] bug: d.vect.area and HTMLMAP
Markus Neteler neteler at itc.it
Tue Apr 16 13:49:48 EDT 2002
On Tue, Apr 16, 2002 at 06:35:38PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > sorry for a new bug report: It seems that d.vect.area does not work properly
> > with the HTMLMAP driver (d.area was fine).
> > Please update:
> >  cvs up src/scripts/contrib/grassmirrorsmap
> > then
> >  cd src/scripts/contrib/grassmirrorsmap
> >  mkgrassmap.sh
> > The resulting 'grass_sites.gif' is fine, but the 'grass_sites.htmlmap' does
> > not contain the expected polygon definitions. Using the old d.area the
> > procedure went fine.
> > I need that to generate the mirrors world map:
> > http://grass.itc.it/index.html
> > Eric, could you please check for a difference between the old and the
> > new implementation which may concern the HTMLMAP driver?
> The HTMLMAP driver only implements two drawing operations, R_text()
> and R_polygon_abs(). d.area uses R_polygon_abs(), while d.vect.area
> uses G_plot_area().
> Eric added G_plot_area() for this purpose. It is based upon
> G_plot_polygon(), but it handles areas containing holes. Both of these
> functions "scan convert" the shape, drawing a series of horizontal
> lines using application-defined functions. For d.vect.area, the
> functions are D_move_abs() and D_cont_abs().
> The bottom line is that the HTMLMAP driver can't realistically
> "reverse" the scan conversion to obtain the original polygons (the
> original shape may not even be a polygon, in the usual sense of the
> word), and re-writing d.vect.area to use R_polygon_abs() isn't
> feasible (that would involve a tesellation algorithm, which is far
> from trivial).
> So, it seems that we will need to maintain d.area for use with the
> HTMLMAP driver. I'll re-enable it in src/CMD/lists/GRASS.
O.k. - I have reverted my changes in the mkgrass.sh script to use
d.area, now the new mirror map is uploaded.
Markus
