[GRASS5] r.minimum
crudeli crudeli at mail.nauta.it
Sat Apr 20 15:22:06 EDT 2002
Dear GRASS users,
I wrote this little script to perform a task similar to r.average and r.median.
this command takes three arguments: base cover output and writes a
raster map "output" containing the minimum values found on the
"cover" map for every different "base" value.
Copy this script to a file called r.minimum (or whatever you like) and
chmod a+x r.minimum
Invocation is
r.minimum  base cover output
Hope you find this useful.
Regards,
Raffaele Douglas Candidi Tommasi Crudeli
__________________
#!/bin/bash
if [ -z "$1" ] || [ -z "$2" ] || [ -z $3 ]; then
     echo
     echo Usage: $0 base cover output
     echo
     exit
fi
if [ ! -f $LOCATION"/cell/$1" ]; then
     echo
     echo "Filename $1 not found"
     echo
     exit
fi
if [ ! -f $LOCATION"/cell/$2" ]; then
     echo
     echo "Filename $2 not found"
     echo
     exit
fi
r.stats -1Cn input=$1,$2|sort -n|awk '
BEGIN {
min=10000000
max=-10000000
cat=1
if ($1==cat) {
if ($2 < min) {
min=$2
if ($2 >max) {
max=$2
}else{
#printf ("%s %f %f\n",cat,min,max)
printf ("%s:%s:%f\n",cat,cat,min)
#printf ("%s=%f\n",cat,min)
cat=$1
min=10000000
max=-10000000
END {
'|r.recode -a input=$1 output=$3
