[GRASS5] Using CVS to manage "experimental" vs. "stable" trees
Glynn Clements
glynn.clements at virgin.net
Tue Apr 23 12:19:07 EDT 2002
Carl Worth wrote:
> At that point, if I understand things correctly, that release branch
> will not have any work done on it after that. The 5.0.1 release will
> not come from an extension of the 5.0.0 branch, but will instead be a
> new branch off of the trunk at some later time.
The 5.0.x releases should be made from the same branch as 5.0.0. They
should differ from 5.0.0 only in terms of bug fixes. It would be
possible to add new modules (which work with the existing libraries),
but I would suggest that developers work on the next major version
instead.
Glynn Clements <glynn.clements at virgin.net>
