[GRASS5] Using CVS to manage "experimental" vs. "stable" trees
Bernhard Reiter
bernhard at intevation.de
Tue Apr 23 13:46:35 EDT 2002
On Tue, Apr 23, 2002 at 05:19:07PM +0100, Glynn Clements wrote:
> The 5.0.x releases should be made from the same branch as 5.0.0.
From the same tree: "grass5".
We will need several release branches for
having parallel release critical bug-fixes for going out of beta.
These branches shall collapse _fast_. (A month or two.)
> They should differ from 5.0.0 only in terms of bug fixes.
Yes, bug fixes and minor enhancements or changes.
Only critical bug fixes in the release branches.
> It would be possible to add new modules
> (which work with the existing libraries),
-> minor enhancements
> but I would suggest that developers work on the next major version instead.
That is what the grass51 tree is for. :)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020423/4c12ca56/attachment.bin
