[GRASS5] Code submission from SJ Geophysics
Markus Neteler neteler at itc.it
Wed Apr 24 03:20:43 EDT 2002
Timur,
(cc grass5)
thanks a lot for your contributions. Since we are ahead a feature
freeze I cannot promise to include them the next days (but maybe
some of your improvements). But later we can certainly add
changes of general interest, which, I am sure, you are contributing.
Your source code package I have stored here for the other developers:
http://mpa.itc.it/markus/tmp/SJGeo.txt
http://mpa.itc.it/markus/tmp/SJGeo.tar.gz
[Developers: we have to define an area where we will handle code
             submissions. Remember that we have more in the queue,
             posted recently]
Thanks again, Timur,
 Markus
On Tue, Apr 23, 2002 at 03:29:37PM -0700, Timur wrote:
> Markus,
> Thanks for you interest to our work.
> My name is Timur Kusherbaev,
> I work for SJ Geophysics Ltd. (you communicate with Syd Visser several
> days ago).
> We use GRASS for geophysical data and I make needed programming to fit
> it to our processing routine.
> I send you file SJGeo.tar.gz with 4 programms:
> 1.  r.recolor - this new program allows to make color management for
> raster map using categories distribution in equal area mode  and
> generate desiring color levels using extended possibilities  for linear
> color interpolation or file color sets. The program works with FP maps
> and has description (file DESCRIPTION in folder with program). This
> program is very usefull to us because able to show maps with different
> kinds of histograms. We hope it will be usefull to others.
> 2.  s.out.ik - s.out.ik - Converts a GRASS site list file into an ASCII
> file with coordinates and information for icons creation. This file can
> be used directly by program v.in.poly for poligons (vector icons).
>  Program also has description.  This program makes actions which can
> seem similar to another programs but it use range of data to produce
> icons and has some ways to regulate kind of icons.
> 3.  d.site.labels - I made some changes (xoffset,yoffset,angle of labels
> rotation) - all changes are in     file CHANGES in directory.
> 4.  r3.to.sites - I also add some possibilities to this program(to
> output in certain range of values) and all  changes also in file CHANGES
> in directory of program.
> Also some changes  made with  "r.digit" program which does not work
> properly. But this changes not go to the way which was planed by
> developpers: we only need to get ASCII file with digitized data. I cut
> part of program which try to produce raster map and simly directed
> output to ASCII file. That is enough to our purpuses but I am not shure
> that it will be resonable to others.
> We use "ps.map" to prepare scripts and I had to do some work around it.
> It does not make boundary box (probably it is old) and when we try to
> use it in Ghostscript we get message on this subject. So I added it and
> removed from ps.map possibility to make automatic frame around output
> because on the one side it is not usefull when we combine two or more
> files to one script, and on the other side it is possible to add any
> desiered frame from the mapping instructions. Also I included
> possibility to rotate text. But I am not shure about all changes at
> present because the program has a lot of modules and another parts which
> can depend on changed ones. I did not study "ps.map" properly to be
> shure that all changes are correct.
> Timur
