[GRASS5] snprintf and other compile errors on IRIX
Carl Worth
cworth at east.isi.edu
Wed Apr 24 09:37:07 EDT 2002
On Apr 23, Eric G. Miller wrote:
> It'd be nice to have a function that was a combination of sprintf and
> strdup: char * G_strdupf(const char *fmt, ...); ??
Absolutely.
Some systems have an asprintf which is printf with allocation. It's
even harder to find than snprintf though. :(
Instead, if you do have snprintf, (one that is capable of returning
indication of whether N was large enough)., then it's pretty easy to
make a function just like what you want. In other projects, I've been
happily using such a function that I snitched from the printf(3) page
on a Linux system. I rarely think about string lengths anymore.
I'll include the function I'm using for reference, (but it doesn't
seem like GRASS could use anything like this yet).
> String handling in C is such a PITA...
Tell me about it.
-Carl
PS. Here's the code I use regularly, (I actually pass in the address
of the char * of interest rather than returning it as you propose).
#include <stdio.h>
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
int sprintf_alloc(char **str, const char *fmt, ...)
int ret;
va_list ap;
va_start(ap, fmt);
ret = va_sprintf_alloc(str, fmt, ap);
va_end(ap);
return ret;
/* ripped more or less straight out of PRINTF(3) */
int va_sprintf_alloc(char **str, const char *fmt, va_list ap)
char *new_str;
/* Guess we need no more than 100 bytes. */
int n, size = 100;
if ((*str = malloc (size)) == NULL)
return -1;
while (1) {
/* Try to print in the allocated space. */
n = vsnprintf (*str, size, fmt, ap);
/* If that worked, return the size. */
if (n > -1 && n < size)
return n;
/* Else try again with more space. */
if (n > -1) /* glibc 2.1 */
size = n+1; /* precisely what is needed */
else /* glibc 2.0 */
size *= 2; /* twice the old size */
new_str = realloc(*str, size);
if (new_str == NULL) {
free(*str);
*str = NULL;
return -1;
*str = new_str;
Carl Worth
USC Information Sciences Institute cworth at east.isi.edu
3811 N. Fairfax Dr. #200, Arlington VA 22203 703-812-3725
