[GRASS5] Script to build babyGRASS for handhelds
Glynn Clements
glynn.clements at virgin.net
Wed Apr 24 11:12:36 EDT 2002
Markus Neteler wrote:
> for amusement I wrote attached script to compile
> a babyGRASS from a standard GRASS 5 source code version.
> It will generate a few important commands based on shared GRASS
> libraries. The size is 2.8MB on Linux.
If you're looking to save memory, generate stripped binaries, e.g.
LDFLAGS=-s ./configure ...
You could also try optimising for size:
CFLAGS=-Os LDFLAGS=-s ./configure ...
If you really want to save memory, you need a display driver which
doesn't require X. E.g. a modified PNG (i.e. GD) driver which outputs
to a framebuffer device.
Glynn Clements <glynn.clements at virgin.net>
